Two lines and two arcs into one slot
  • Thread starter Thread starter O.Ramone
  • Start date Start date
O
O.Ramone
Guest
Hello people
I have a little problem with my sketching. I have made a drawing consisting of two lines and two arcs, that you can se on the picture. How can I make these separate lines/arcs into one slot?
I do this because I want to copy the slots easily and use them several places in the drawing.
(I know I can make a slot directly in SW, but I need to know how I can make one line out of several lines, arc etc.)
Hopefully you understand what I mean!:)
Hey O!
In SW there is an slot option on the sketch toolbar and it allows a few different drawing options. There are also options to group select a number of sketched slots and make them all equal in size. This is of course depending on your SW version.
You can also make a block out of your sketch and place that easily in many locations.See the help menu for sketched slots and blocks for the most current information.
B
Thanks for the information. Yes, I just marked the different sketched slots and clicked make "Make Block". I thought I had tried that before, but probably not. Now I can copy the block easily and place them other places in the drawing. Thanks!
