Trigger
  • Thread starter Thread starter nino67
  • Start date Start date
N
nino67
Guest
Hail,
I have despaired need of help.
I have mailed a [trigger] on the event [login], the avowed [dll] doesn't exist and. [intralink] refuses of effect the [login].
is he/she/it/you possible eliminate the [trigger] without enter [intralink]?. do possible [
Ah, I think I understand. You set up a pre-login trigger, but the DLL doesn't exist, so any login attempt is blocked? Interesting situation - I hadn't thought of this case before.
One thing you can do, if you remember the name of the DLL and function, is compile a trigger that registers that function, and the function just returns zero. Then, put the DLL in place and log in.
Or, you should be able to eliminate the trigger by connecting to Oracle and updating the proper tables, assuming you have access to the data server. Contact PTC's tech support for this - they should be able to step you through the process.
Dan
Thank you,
but in the meantime here the solution that I put to disposition (in Italian) of contingent careless consumers like me.
C:\>sqlplus
SQL*Plus: Release 8.1.7.0.0 - Production on Mer Nov 6 12:20:23 2002
(c) Copyright 2000 Oracle Corporation. All rights reserved.
Immettere il nome utente: SYSTEM
Immettere la password:
Connesso a:
Oracle8i Enterprise Edition Release 8.1.7.2.1 - Production
JServer Release 8.1.7.2.1 - Production
SQL> desc pdm.pdm_trigger;
Nome Nullo? Tipe
TRIGID NOT NULL NUMBER
TRIGNAME NOT NULL VARCHAR2(80)
TRIGEVENTTYPE NOT NULL NUMBER
TRIGTYPE NOT NULL NUMBER
TRIGISENA NOT NULL NUMBER
TRIGISREQ NOT NULL NUMBER
TRIGISLOG NOT NULL NUMBER
TRIGDESC VARCHAR2(2000)
CREATEDON DATE
CREATEDBY VARCHAR2(80)
MODIFIEDON DATE
MODIFIEDBY VARCHAR2(80)
SQL> select trigname, trigisena from pdm.pdm_trigger;
TRIGNAME
TRIGISENA
AAA
1
SQL> update pdm.pdm_trigger set trigisena=0;
Aggiornata 1 riga.
SQL> commit;
Completata esecuzione commit.
SQL>
