Tree Reordering
SKUDENT
SG
I have tried to combine a few codes and came up with something workable when running it from VB editor but not when it run in CATIA V5 itself, it always freeze up.
I did use some codes from [URL unfurl="true"]https://scripts4all.eu/graph-tree-reordering-vba/[/url] and thread560-416671
Need some enlightenment on why does it freezes up when it runs via CATIA V5 R21
Code:
Option Explicit
Dim selectProducts As Products
Dim Excel As Object
Dim Item As Product
Dim a, b, d, e As Integer
Dim x, m, g, c As String
Dim z, p, y As Integer
Dim save As Variant
Dim prodCnt, position As Integer
Dim continue As Integer
Dim CATIA, doc, prod, sel
Dim winAutomation As CUIAutomation
Dim desktop As IUIAutomationElement
Dim allWindowsCond As IUIAutomationCondition
Dim childs As IUIAutomationElementArray
Dim i As Long, currChild As IUIAutomationElement
Dim catiaWindow As IUIAutomationElement
Dim graphWinCond As IUIAutomationCondition
Dim graphWin As IUIAutomationElement
Declare Sub Sleep Lib "kernel32" (ByVal dwMilliseconds As Long)
Sub CATMain()
        save = MsgBox("Did you save your file before using macro?", vbYesNo)
        If save = 7 Then GoTo 1
Set CATIA = GetObject(, "CATIA.Application")    ' get CATIA Application
    Set doc = CATIA.ActiveDocument
    Set prod = doc.Product
    Set sel = doc.Selection
    Set winAutomation = New CUIAutomation
    ' get reference to the root element (desktop)
    Set desktop = winAutomation.GetRootElement
    ' retrieves a predefined condition that selects all elements
    Set allWindowsCond = winAutomation.CreateTrueCondition
    ' find all elements & put them into element array
    Set childs = desktop.FindAll(TreeScope_Children, allWindowsCond)
    ' select top product in a CATIA tree
    sel.Clear
    sel.Add prod
    On Error GoTo 3
    Set selectProducts = sel.Item2(1).Value.Products
    'Launch Excel
    Set Excel = CreateObject("Excel.Application")
    Excel.Visible = True
    Excel.workbooks.Add
    'Headers
    Excel.cells(1, 1) = "Part Number"
    Excel.cells(1, 2) = "NUMBERING"
    Excel.cells(1, 3) = "Instance Name"
    Excel.cells(1, 4) = "ORDER"
    Excel.Range("A1, D1").Font.Bold = True
    Excel.cells(1, 4).Interior.ColorIndex = 15
    'Product counts(Num of products)
    prodCnt = prod.Products.Count
    On Error Resume Next
    'Input values into excel
    x = 1
    g = 2
        Do While x < prodCnt + 1
        'list down part number, instance num and initial position
        Set Item = selectProducts.Item(x)
        'initial list
        Excel.cells(g, 1) = Item.PartNumber
        Excel.cells(g, 3) = Item.Name
        Excel.cells(g, 4) = x
        Excel.cells(g, 4).Interior.ColorIndex = 15
        Excel.Worksheets("Sheet1").Range("A:D").Columns.AutoFit
        a = Len(Item.PartNumber) 'xxxx
        b = Len(Item.Name) 'xxxx.xxx
        c = Right(Item.Name, b - a - 1) 'instance number
        d = prodCnt
        e = Len(d)
        Excel.cells(g, 2) = Item.PartNumber & "."
        Do While e - Len(c) > 0
        Excel.cells(g, 2) = Excel.cells(g, 2) & "0"
        e = e - 1
        Loop
        Excel.cells(g, 2) = Excel.cells(g, 2) & c
        g = g + 1
        x = x + 1
    Loop
Excel.ScreenUpdating = True
'Sorting to alphabetical order
Excel.Worksheets("Sheet1").Range("A:D").Sort key1:=Excel.Range("B2"), Header:=1
'txtbox to continue or end macro
Dim closeExcel As Variant
    closeExcel = MsgBox("Would you like to close Excel? Press No if Continuing.", vbYesNo)
        If closeExcel = vbYes Then
        Close Excel
    Excel.ActiveWorkbook.Close SaveChanges:=False
    Excel.Quit
    GoTo 1
End If
'end of excel
'm is going to be the number for the row in excel
'p is going to be the number for the list in product tree
m = 2
Do While m < prod.Products.Count + 2
    p = 0
    Do While p < prod.Products.Count
        Set Item = selectProducts.Item(p + 1)
        'if item instance name is = to name in excel cell then exit loop and proceed to call
        If Item.Name = Excel.cells(m, 3) Then
        Exit Do
        End If
        'p+1 to increase p value by one for each loop
        p = p + 1
        Loop
    Call CATOrder1
    Call CATOrder2
'm+1 to increase p value by one for each loop
m = m + 1
Loop
Call CATOkay
GoTo 1
3:  MsgBox "Select a product before running macro."
    Excel.Quit
1:
    Close Excel
    Excel.Quit
End Sub
Sub CATOrder1()
    If m = 2 Then
        sel.Clear
        sel.Add prod
        CATOpen
    End If
    ' loop through all element and find CATIA by window name which contains "CATIA V5" string
    For i = 0 To childs.Length - 1
        Set currChild = childs.GetElement(i)
        If InStr(currChild.CurrentName, "CATIA V5") Then
            Set catiaWindow = currChild ' set main catia window
        End If
        'Debug.Print currChild.CurrentName, currChild.CurrentClassName
    Next
    Set graphWinCond = winAutomation.CreatePropertyCondition(UIA_NamePropertyId, "Graph tree reordering")
    'wait for Graph window to open and get it
    Do
        Set graphWin = catiaWindow.FindFirst(TreeScope_Children, graphWinCond)
        'do not freeze application in case of infinite loop
        DoEvents
    Loop While graphWin Is Nothing
    'Focus on the graph reorder window
    graphWin.SetFocus
    'tab key input to change from "OK" to Listbox
    SendKeys "{TAB 3}", 0.2
    Sleep 10
    graphWin.SetFocus
    'move selection back up to top
    For y = 0 To prod.Products.Count - 2
        SendKeys "{UP}", 0.2
    Next
    Sleep 10
    graphWin.SetFocus
    'p-1 number of down input to select the target
    For y = 0 To p - 1
        SendKeys "{DOWN}", 0.2
    Next
    Sleep 10
End Sub
Sub CATOrder2()
        End If
        ' Debug.Print currChild.CurrentName, currChild.CurrentClassName
    Next
    Do
        ' do not freeze application in case of infinite loop
        DoEvents
    ' get OK button
    Dim btnOKCondition As IUIAutomationCondition, btnOk As IUIAutomationElement
    Set btnOKCondition = winAutomation.CreatePropertyCondition(UIA_NamePropertyId, "OK")
    Set btnOk = graphWin.FindFirst(TreeScope_Children, btnOKCondition)
    ' get Move Down button
    Dim btnMoveDownCondition As IUIAutomationCondition, btnMoveDown As IUIAutomationElement
    Set btnMoveDownCondition = winAutomation.CreatePropertyCondition(UIA_NamePropertyId, "Move Down")
    Set btnMoveDown = graphWin.FindFirst(TreeScope_Descendants, btnMoveDownCondition)
    ' get Move Up button
    Dim btnMoveUpCondition As IUIAutomationCondition, btnMoveUp As IUIAutomationElement
    Set btnMoveUpCondition = winAutomation.CreatePropertyCondition(UIA_NamePropertyId, "Move Up")
    Set btnMoveUp = graphWin.FindFirst(TreeScope_Descendants, btnMoveUpCondition)
    ' get Apply button
    Dim btnApplyCondition As IUIAutomationCondition, btnApply As IUIAutomationElement
    Set btnApplyCondition = winAutomation.CreatePropertyCondition(UIA_NamePropertyId, "Apply")
    Set btnApply = graphWin.FindFirst(TreeScope_Descendants, btnApplyCondition)
    ' control pattern definition (button click)
    Dim patApply As IUIAutomationInvokePattern, patMoveUp As IUIAutomationInvokePattern, patMoveDown As IUIAutomationInvokePattern, patOK As IUIAutomationInvokePattern
    Set patMoveUp = btnMoveUp.GetCurrentPattern(UIA_InvokePatternId)
    Set patMoveDown = btnMoveDown.GetCurrentPattern(UIA_InvokePatternId)
    Set patOK = btnOk.GetCurrentPattern(UIA_InvokePatternId)
    Set patApply = btnApply.GetCurrentPattern(UIA_InvokePatternId)
    'to invoke the number of button click down to bottom of list
    For i = 1 To prod.Products.Count - p
        ' button click events invoked
        patMoveDown.Invoke
    Next
    'Press OK
    patApply.Invoke
    Sleep 10
    graphWin.SetFocus
    'tab key input to change from "Apply" to "OK"
    SendKeys "+{TAB}", 0.5
    Sleep 10
End Sub
Sub CATOkay()
        End If
    Next
    Do
        DoEvents
    ' get OK button
    Dim patOK As IUIAutomationInvokePattern
    graphWin.SetFocus
    patOK.Invoke
    Sleep 10
End Sub
Sub CATOpen()
' launch "Graph tree reordering" command
        CATIA.StartCommand "Graph tree reordering"
        CATIA.RefreshDisplay = True
        Dim graphopen As Integer
4:
        graphopen = MsgBox("Is the graph reorder open?", vbYesNo)
        If graphopen = 7 Then
        GoTo 4
        End If
End Sub
I run it from the Visual Basic Editor in CATIA V5 R21.
It suppose to read of the part name and instance number from the Graph tree and sort it in EXCEL.
Furthermore, the script will compare the list in EXCEL with the Graph Tree and reorder to tree using UIAutomation inputs.
It is like a speed up version of clicking those buttons.
I managed to reorder the graph tree containing 200+ parts in about 5 minutes.
You can not run the code which automates CATIA V5 UI from within CATIA V5, it will freeze. You can automate CATIA and CATIA User Interface only from the outside (VB.NET, VBScript, Excel VBA). So move your code to Excel VBA and it should work.
Tesak
- Play Tetris in CATIA V5 drawing
Thank you very much, I go shall work on it!
