trajpar with var sec sweep
  • Thread starter Thread starter miked
  • Start date Start date
M
miked
Guest
Can anyone explain how trajpar works with a var sec sweep?
I have used it in the tutorials but have never fully understood it.
I know that its value is equal to 0 at the start point and 1 at the endpoint.
The example I was given was sd1=trajpar*4+1 to control the value of a sketcher dimension.
This is supposed to provide better control over the section but I think I am missing something.
Anyone have a simple explanation? What does it control exactly?
Mike
You've virtually explained it yourself.
trajpar is a built-in variable that relates to the distance along a swept trajectory. As you say, it goes from 0 to 1.
So in your example, sd1 will vary from 1 to 5, linearly.
If you think of it in terms of graphing x against y,
trajpar = x, with limits 0..1
formula = y (eg: y = 4x + 1)
You can control dimensions in the sketch because you know the limits of the graph.
Ed
