TRACKING WEIGHT OF COMPONENTS
  • Thread starter Thread starter davids163
  • Start date Start date
D
davids163
Guest
I need to track the weight of components and assemblies and report the value as a parameter on drawings. Can anyone help?
Found this one at:
http://www.geocities.com/edwinmuirhead/pro-how/
How do I enable a part to calculate its own weight?
Create a parameter called weight (real no.)
Add a relation:
weight=mp_mass()
Ensure the density (Setup | Density) is correct for the model and units
After regeneration the model will calculate and store weight
This parameter can be shown on drawings using &weight
Note that you can control the number of dp on drawing separately from the model(s), just type:
&weight[.2]
Will display to 2 dp....
Thanks for the tip Doug!! I didn't know you could do that.
You should also note means current model which for a part is the part and for an assembly is the top level.
A path can be entered here in an assembly to any specific component and this is what will be computed.
