Tolerances
  • Thread starter Thread starter kujur11a
  • Start date Start date
K
kujur11a
Guest
Hi to all,
I have one problem whenever I am trying to give dimensional tolerances to my dimension it applies to all the dimesions. But I dont want to put tolerances to some of them or want to have some other type of tolerance. So what shall I do in that case.Is there any option in draw setup for that rather than doing it manually changing through properties.
thanks for replying
kujur
You can pick as many dimensions as you need in drawing, RMB and change their tolerance display all at once. Remember, tolerances are set depending on the config.pro settings at the time the feature is created in part mode. So make your config settings correspond to how you want the majority of your dimensions to appear and you won't have to change so many.
