tolerance display
  • Thread starter Thread starter wwwvenky
  • Start date Start date
W
wwwvenky
Guest
in drawing mode,i need only one dimension with tolerance among all. is there any config file or any other methods.
please let me know,
bye
Tolerance display in drawing mode is controlled by your .dtl file. Click Advanced > Draw Setup and set tol_display to yes.
You probably want all your dimensions set to a tolerance mode of normal and the one you're interested in set to the appropriate mode. Your tolerance mode is controlled by the config.pro option tol_mode IIRC. Depending on what value it's currently set for, you may have to change the tolerance mode of all the dimensions to nominal.
David Martin
Torgon Industries
