"toggle type" in Wildfire 2003170
  • Thread starter Thread starter ahellmann
  • Start date Start date
A
ahellmann
Guest
2001: Toggle type command is show as linear in Wildfire. After this you have to run the modify attachment command to convert a diameter dimension to a linear dimension and make it exactly horizontal or vertical. With my 2003170 of Wildfire this works only for dimensions coming from the 3D model. I haven't found a way to convert created dimensions from diameter to linear.
Andreas
