To change the default settings in proe 2000i
  • Thread starter Thread starter pintu
  • Start date Start date
P
pintu
Guest
hellow this is pintu here
i want tochange the set up units as defaut settings . any body will help me at that matter i will be glad to recive. thankx
pintu_33@indiatimes.com
Explain your problem first - do you have problem or what?
Speling
In your config.pro file it is this option.
PRO_UNIT_LENGTH 8=>
pro_unit_length unit_xx is one option. The best option would be
template_solidpart \directory\standardpart.prt. In other words, create template parts and assemblies with pre-defined views, standard datum planes, layers and coordinate system.
template_designasm \directory\standardassy.asm
is for start assembly.
donha can u explain your comments clearly plz
i understood fishnet and succeded with it can u help me your comment donha
magi
