To bring dwg file into memory
  • Thread starter Thread starter roswal
  • Start date Start date
R
roswal
Guest
Hi everyone,
I am trying to read drw file from local disk using ProMdlRetrieve(), but it needs me to keep the proe session with the dwg file to read open. Then only it reads the table information from the face of the drawing I intend to read.
Can anybody tell meset of API routines which will allow me to bring the dwg file into memory(manual interaction with Proe is not feasible solution or else ProFileOpen() cld have been used I guess) so that I wont require to open the dwg file open in the proe session, since I have to read large chunk of dwg file almost 20k files.
I am trying to create exe file.
Thanks & Regards,
Rocky
