C
canners96
Guest
After updating from Creo 3.0 M010 to Creo 3.0 M020 we have a problem with our company created format sheets where the title block cell / row heights all seem to reduce in height but the text stays where it should be. Note: This problem has never occurred before on any release of Creo.
See image above for visual representation.
Basically if you open the format file it opens perfectly and is as you would expect to see it. However if you create new drawing using the company standard template from of a part / assembly then the cell/row heights in the title block change but the text remains where it should be.
Anyone had this problem ? Know a reason / fix for it ?
