Title block cell heights irregularity after updated from Creo 3.0 M010 to M020
  • Thread starter Thread starter canners96
  • Start date Start date
C
canners96
Guest
I have just updated to Creo 3.0 M010 to Creo 3.0 M020.
After update there is a problem with the title blocks in the existing formats I have.
If you open the company created format file itself all appears fine.
However if you create new drawing from a part or and assembly and use the company created format file then the title block cells heights all get reduced in height but the text that should have been in them remains in the position where the cells should have been.
Anybody else had this problem ? Or know a fix ?
btw The format has worked with every Creo release (Creo, Creo 2 and Creo 3 M010) without problem until M020
