Greenalleycat
- Jul 12, 2021
- 631
The current weekend DIY project is to replace the "retaining wall" alongside my driveway that supports my neighbour's lawn. I say 'retaining wall' loosely as it is literally four trees chainsawed to height with some planks behind it...
Anyway, we've made great progress getting the posts in and bottom boards on
We are now going to get the filter cloth, gravel, and drain in
The problem is, getting the drain in is going to be a prick of a job
It's a very tight space due to driveway/property boundary, existing "wall", and the various rocks peppering the slope
I'm confident that a proper water buildup is unlikely so we're putting a drain in for good practice as much as anything
So the question is, if the drain ends up 300mm from the base of the wall where we actually has space, does that matter?
Bearing in mind we will be mostly backfilling with free draining gravel wrapped in cloth anyway
Interested in your opinions
Edit: added a photo
Edit: added a photo
