pelelo
Geotechnical
- Aug 10, 2009
- 357
Engineers,
I am performing a timber pile design. Similar to the steel pile design, after i compute my lateral moment (LPILE) and make sure that the lateral deflection is adequate, i compare the steel pile resisting moment (f'y and section modulus) against the computed moment (LPILE), if resisting is greater than the computed moment, then the section is ok.
I understand the same procedure should be followed for timber piles. However, Does anyone knows where to get the section modulus of timber piles?, In my case, i plan to use the southern pine specie, 8 inches diameter at the butt and 7 inches diameter at the tip, with a lenght of 20 ft.
I have been trying to look for tables, similar to the steel profiles, but haven't found anything. The Timber pile design and construction manual is somewhat vague at this.
Please advise,
Please advise,
