Blobajob88
Chemical
Can someone please assist? If I have a pump with a pressure gauge, followed by a diaphragm valve on the discharge side and I start to throttle the flow with the diaphragm valve, why does the pressure start to increase and therefore flow decrease? If you narrow a pipe, wouldn't Bernoulli's principle apply i.e. the flow stays the same and the water would just go quicker through the restriction. it seems it applies up to a point.
Ben
Ben
