Alistair_Heaton
- Nov 4, 2018
- 9,820
I am building using aerated concrete blocks and ceiling plates. I will admit it's a DIY workshop/bar building
There is a 6 meter by 15 meter floor of ceiling/floor plates which are 600 mm width x 215mm thick x 6000mm long. I want to tie them together to form a shear diaphragm.
The design manual also says to use circular reinforcement to stop cracking between panels 10mm dia.
I can't get hold of corrosion resistant rebar plus will have issues getting it welded together if I get hold of ZN plated.
I can get hold of plated ZN threaded 3m lengths of bar 8,10,12mm dia.
How stupid is using 12mm threaded ZN rod joined by ZN hex nuts instead of black iron/steel rebar?
Locally they are telling me to just use black iron but my research says this a big no no with aerated concrete as it sucks moisture like a sponge, and you will have corrosion issues in 5 years if you do.
I haven't been a practising Engineer in over 20 years and never worked with concrete practically even when I was practising and this aerated foam autoclaved concrete is a steep learning curve designing and building with it. It has huge advantages compared to normal building materials but has some huge minus issues with this water migration and movement internally.
