Hi All,
A few days ago I found out that when you are in the assembly Component Placement Ribbon you can un-dock the menu panels. I thought "hey this is cool, this thing always covers up my datum planes and I have to hide/unhide it." Great day right? Wrong.
Now when ever I try to edit or assemble a part I can't see the placement panel. I have no idea how to find it.
http://support.ptc.com/WCMS/files/95528/en/4576_QRC_Card_V5_EN_Pgs.pdf
Update: Our CAD admin thinks it might be something in my config.pro. Attaching it for reference.
!lindejos Mapkeys and Configs 20160531
mapkey gwb ~ Select `main_dlg_cur` `appl_casc`;\
mapkey(continued) ~ Select `main_dlg_cur` `appl_menu.left_pane.app_help_casc`;\
mapkey(continued) ~ Close `main_dlg_cur` `appl_casc`;~ Command `ProCmdRibbonOptionsDlg` ;\
mapkey(continued) ~ Select `ribbon_options_dialog` `PageSwitcherPageList` 1 `colors_layouts`;\
mapkey(continued) ~ Open `ribbon_options_dialog` `colors_layouts.Color_scheme_optMenu`;\
mapkey(continued) ~ Close `ribbon_options_dialog` `colors_layouts.Color_scheme_optMenu`;\
mapkey(continued) ~ Select `ribbon_options_dialog` `colors_layouts.Color_scheme_optMenu` 1 `2`;\
mapkey(continued) ~ Activate `ribbon_options_dialog` `OkPshBtn`;
mapkey hh ~ Timer `UI Desktop` `UI Desktop` `popupMenuRMBTimerCB`;\
mapkey(continued) ~ Close `rmb_popup` `PopupMenu`;~ Activate `rmb_popup` `HideFeat_PushBtn`;
mapkey $F10 %dwg;
mapkey uu @MAPKEY_LABELunhide object;\
mapkey(continued) ~ Select `main_dlg_cur` `PHTLeft.AssyTree` 1 `node3`;\
mapkey(continued) ~ RButtonArm `main_dlg_cur` `PHTLeft.AssyTree` `node3`;\
mapkey(continued) ~ PopupOver `main_dlg_cur` `ActionMenu` 1 `PHTLeft.AssyTree`;\
mapkey(continued) ~ Open `main_dlg_cur` `ActionMenu`;\
mapkey(continued) ~ Trail `UI Desktop` `UI Desktop` `PREVIEW_POPUP_TIMER` \
mapkey(continued) `main_dlg_w1
HTLeft.AssyTree:<NULL>`;~ Close `main_dlg_cur` `ActionMenu`;\
mapkey(continued) ~ Activate `main_dlg_cur` `UnhideFeat_PushBtn`;
mapkey dpo @MAPKEY_LABELtoggle datum planes;~ Command `ProCmdEnvDtmDisp` 0;
browser_limit_to_ie9_mode yes
mapkey md ~ Activate `main_dlg_cur` `page_Analysis_control_btn` 1;\
mapkey(continued) ~ Command `ProCmdNmdTool` 1;
mapkey gbb ~ Select `main_dlg_cur` `appl_casc`;\
mapkey(continued) ~ Select `ribbon_options_dialog` `colors_layouts.Color_scheme_optMenu` 1 `5`;\
mapkey eon @MAPKEY_LABELeverything off normal;\
mapkey(continued) ~ Activate `main_dlg_cur` \
mapkey(continued) `igToolbar_AncestorIGT_IGT_GRP_inh396938342.proe_win|.mcs29658718_mp|select_\
mapkey(continued) all_check` 1;\
mapkey(continued) all_check` 0;\
mapkey(continued) ~ Select `main_dlg_cur` \
mapkey(continued) `igToolbar_AncestorIGT_IGT_GRP_inh396938342.proe_win:casc340798662`;\
mapkey(continued) ~ Close `main_dlg_cur` \
mapkey(continued) ~ Command `ProCmdNamedViewsGalSelect` `Default`;\
mapkey(continued) ~ Command `ProCmdEnvShadedEdges` 1;
mapkey stl @MAPKEY_LABELsave as stl;~ Close `main_dlg_cur` `appl_casc`;\
mapkey(continued) ~ Command `ProCmdModelSaveAs` ;~ Open `file_saveas` `type_option`;\
mapkey(continued) ~ Close `file_saveas` `type_option`;\
mapkey(continued) ~ Select `file_saveas` `type_option` 1 `db_549`;
spin_with_silhouettes yes
skip_small_surfaces no
shade_quality 8
draw_models_read_only no
def_layer layer_copy_geom_feat 00_copy_geom
def_layer layer_cosm_sketch 00_cosm_sketch
def_layer layer_ext_copy_geom_feat 00_copy_geom
proe_memory_buffer_size = 500
step_appearance_layers_groups yes
step_out_material no
