The Bones module allows you to rapidly bu
  • Thread starter Thread starter daduhe
  • Start date Start date
D
daduhe
Guest
The Bones module allows you to rapidly build out the bare-bones structure of a site by importing a YAML file containing an outline of the menu structure and page titles you need to set up.
The philosophy of the Bones moduledvd box set is to solve one specific problem (speeding up node and menu building) with a minimum of setup and configuration, rather than trying to be a swiss army knife. For more complex and sophisticated types of automated site building and configuration, you may be interested in the excellent Patterns module.
Setup
In order to use Bones, a user must have lost dvd three permissions: access administration pages, administer menu, and administer nodes.
Bones was created to bypass the tedious process of manually adding nodes, expanding the Menu Settings fieldset, entering a menu title, choosing a parent item and weight and submitting for each page onSmallville dvd a mostly "static" site. YAML provides a relatively lightweight way to construct a site outline, and using that outline Bones can build out a skeletal site structure in one step.
Bones also requires the SPYC YAML parser, which is Disney dvd
available separately. Download SPYC from http://spyc.sourceforge.net/ and unzip it into the Bones module directory.
Each item in the outline must minimally provide a title, but as shown above you may also provide additional attributes.
name
If you want a node to be attributed to a specific user on yourBoston Legal dvd
Drupal site, set the name attribute with their Drupal user name.
Upon uploading the YAML Grey's Anatomy dvd
file, the Bones module will create stub nodes and build menu items pointing to them.
Cold Case dvd
Mi5 dvd
A sample Bones import file might look like this:
-title: Products
-title: WidgetMaster 2008 Lite
-title: WidgetMaster 2008 Pro
-title: News
-title: WidgetMaster 2008 Wins Prestigious Award
type: story
-title: About Us
path: about
-title: History
body: Brief company history goes here
-title: The Team
-title: John P Hackworth, President
-title: Randy Waterhouse, VP of Engineering
-title: Eliza, Chief Financial Officer
-title: Contact Us
path: contact
-title: Map & Directions
Usage
Bones provides a single form for importing data, Scrubs dvd
which can be found under Administer > Site Building > Bones, (admin/build/bones).
type
This may be the machine-friendly name of any content type currently available on your Drupal site.
path
By default, Bones will attempt to automatically build Path aliases for you, but you can override that by providing the path attribute. This is useful if you want to link to an existing node or path provided by another module, such as the site contact form in the example above.
body
You may also provide some stub content using the body attribute. Theoretically you should be able to import as much content as you like if it remains on one line, but this has not been tested.
In fact, Bones will attempt to add any attribute you provide to the nodes it creates, so in theory you should also be able to set other attributes such as publication date, status, front page promotion, et cetera, but this has not been tested.
I will not be continuing development on the Drupal 5 branch; all future improvements & features will go into the Drupal 6 version.
