temperature ranges in Fluent for Catia
  • Thread starter Thread starter atrumpour
  • Start date Start date
A
atrumpour
Guest
I'm attempting to model a high-temperature flow using Fluent for Catia V5, but when I try to set any boundary temperature value, I am given a dialog box saying "Sanity Check: Temperature value must be inferior to 2000K and superior to 100K". Similarly, if I try running a simulation where the temperature goes above 2000K at any point, I get the same error message.
Does anyone know why this happens? And more to the point, is there a way I can turn off the warning, or otherwise correct this to allow for higher (or lower) temperatures?
Thanks very much!
