CuriousElectron
- Jun 24, 2017
- 194
Greetings,
I've got a steel mast that supports an antenna and a stainless steel control panel. I'd like to provide lightning protection for the pole and protect internal control equipment inside the control panel from lightning strikes. My thought is to install a lightning rod atop the pole and run down a dedicated ground wire down to ground rod. The steel pole will be installed on a concrete footing and will not be bonded to ground rod. From Ohm's law, the ground wire will offer a path of lowest resistant to ground for lightning energy. Since the pole is not bonded to ground rod, it will carry some energy, but hopefully not "significantly enough" to fry equipment inside the control panel. I'm also going to spec out lightning protection units to be located in the panel to make the lightning system protection more effective.
What you all think?
Best Regards,
EE
What you all think?
Best Regards,
EE
