I work with a manufacturer who needs to tap a 6" chilled water line to a 4" hose, to sustain a critical process while a smaller chiller is being replaced. The 6" water line is insulated, clad, heat traced, etc.,It would be painful to tear into all that for just this temporary job, and that would also disrupt the process.
There is a y-strainer, however, in favorable location, and I have an idea. If I replace the end cap of the strainer with a (presumably custom) flange, I could thus bolt on a ~4" hose connection instead of the end cap. Basically this would be like a cleanout fitting, but with a big hole. The tapped flow would bypass the strainer, but we could add a strainer downstream. On further reflection, we might even mount another, 4" Y strainer to the cap of the 6", to provide a dual strainer and hose tap in one assembly. See the concept sketch. I see no reference to anything like this...If this is nuts, I'd like to find out ASAP. Any thoughts?
