Jul 8, 2003 #1 J jperkins Guest Ho do you select and not display the text from tapped holes on models. jperkins
Jul 8, 2003 Thread starter #2 J jabbadeus Guest Are you using 2001? Underneath Utilities > Environment you can turn off all 3D Notes, which will turn off the note from your standard hole. But you should be able to select the note, right click, and choose Erase to turn off its display. Hope this helps. Dave Martin
