May 20, 2003 #1 G gkling Guest This maybe simple but I'm struggling. I've got a table and I want the rpt.index of the repeat region to go upwards not downwards. Hope this makes sense. Greg
May 20, 2003 Thread starter #2 G gurveen Guest while creating table you need to select ascending insted of descending(default)
May 21, 2003 Thread starter #3 G Guest Guest You can modify an existing table. Select: Table > Repeat Region > Sort Regions > {pick the region} > Add > {select a sort order} > {select a column to sort}
