Tables for multible assemblies
  • Thread starter Thread starter wildmodeler
  • Start date Start date
W
wildmodeler
Guest
Here goes we have assemblies Ill call them 301, in these assemblies there are 302, 303, .....The 301 is all of the assemblies together. The 302 & up are sub assemblies. We would like to use the same tabel for BOMs for all Here is a pic.View attachment 5757
I know you can set the column to a model but then the total QTY goes away. Anybody know how to do this?
Making progress. I have obtained the extra qty columns. But now my repeat region relations dont work. I added rpt.qty to the sub assembly columns and used column/model to set the columns to there sub assemblies. This worked great but the total qty went away all except the A/R bulk parts that get the A/R from a relation the total QTY is gone!
This is the relation:
IF asm_mbr_part_number == "PART_NUMBER"
Quantity="A/R"
else
Quantity = rpt_qty
EndIf
It worked before just added 4 more columns and used rpt_qty in them
You will need to replace "rpt.qty" with "&rpt.rel.Quantity" in your repeat region.
