system parameters for material....
  • Thread starter Thread starter element
  • Start date Start date
E
element
Guest
Does anyone know what the system parameter for material is? that is when you
assign a material to the part using set-up>material>assign .
I want to have the drawing automatically fill in based upon what is assigned
in set-up.
OR is there a way to add another item to the material MAT file, i.e. can I
add a line called name=steel. Using a text editor I can add this to the MAT
file however Pro doesn't reconize it or sees it when I try to set a relation
material=material_param(name).
Steve
It doesn't matter, you can add any parameter for material but you should implement the same parameter in drawings (e.g. BOM Table).
