System Error: HELP Please
Wazy01
49
Could you please help with the following error
Imported input file from Nx-Nastran then run static analysis , it worked
Now I an doing fatigue analysis a-N method. There is no fatigue results--even the program run
the op2 shows only the static results. with no fatigue
the f06 shwoa the following messages
*** USER WARNING MESSAGE 4597 (GPST1A)
A SURFACE OR VOLUME CARD WITH ID = -10 REFERENCES A SET ID =10
WHICH CONTAINS NOELEMENTS OF PERMISSIBLE TYPE.
*** SYSTEM FATAL MESSAGE 3002 (FTGGPS2)
EOF ENCOUNTERED WHILE READING DATA BLOCK OESFTG (FILE 103) IN SUBROUTINE FTGGPS2
0FATAL ERROR
I attached the f06 files
Please do not hesitate if you have any comment
 https://files.engineering.com/getfile.aspx?folder=dd36dc22-accf-431e-9aa4-202cdb55daa7&file=fatreve1.zip
