syntax for programing in drawing
  • Thread starter Thread starter magi
  • Start date Start date
M
magi
Guest
i have a part programed in the manner either one of 2 holes in the part apper as per user input.
i need to do the program in drawing so that i can show only one dimension of hole which is viewed.
what is the syntax for if case
if syntax
set1
else
set2
endif
i need to know the syntax
plz help out
regards
mahendran
Hi, If u know that first have to create a view state, the second step is very easy: the if condition has to be ruled by a feature dimension, so for example you can write
if d:21>=5
set state state name
else
endif
As you have a dimension that either could exist or not exist I think is better if the drawing program is rouled by a parameter, such as it could change between two values (use exist option in part relation) so u can use these two values for set the view states.
I hope it is useful for u; I you have some doubts write me at zalb76@yahoo.it
regards
