> P.O.O "relative accuracy" default is .012 and not .0012.
My 'out of the box' templates are .0012 Relative.
Reference also:
TPI 32869
2008-10-10_173521_EERN_Discussion_on_Accuracy_-_Abs_vs_Rel.z ip
(my link to the doc is dead so I'll post)
(Rumor has it that factory recommendations are changing to Absolute Accuracy?)
> Also, accuracy is a parameter Pro/E uses to converge it's solver ...
I understand accuracy quite well, thank you. It took wading thru tons of used
car salesman cum CAD reseller trash talk and countless eggspurts parroting it
to reach that understanding.
> can't figure out where to begin where I dislike ...
It is what it is and I assume the quibbles are legitimate. I'm not selling
the software nor do own a seat. Closest I can come is FEMAP. I'd rather take
a beating than model anything with it. I don't know it well. Maybe if I knew
it better?
> CV became a kluge and Pro/E took over then in turn
> Pro/E became a kluge and Solidworks took off)
Now SW is a kludge and Alibre will ...?
I don't know enough or go back far enough to argue the 'trend' theory but Pro/E
was first released in '88 and PTC bought CV / CADDS in '99. I don't know CADDS
but browsing its documentation; I can see where some of the functionality was
ported to Pro/E, the data structures and handling are different, interface is
different. Whether or not something is a kludge is a matter of opinion and
perspective. We talking (coming up from low end CAD ownership, I've come to
hate the terms) "user friendly", "intuitiveness" or 'get the job done'
functional? What's the 'job'? FWIW, kludgey old CADDS is one of two programs
that I know of that boast a 'totally digitally designed in' heavy aircraft.
(Antonov)
> btw which airframer uses UG ????
My only intimate dealings with aircraft design was over ten years ago as an R&D
mechanic. It was a UG (initially ported from the drafting board) shop largely
because of association with MD. I still associate with tool / die / mold
designers using UG. Assertions that it is unsuitable for 'complex design' are,
quite simply, ignorant skool kid talk.
Pro/E is a Winner. Solidworks is a Winner.
So what? So are Autodesk and Wal-Mart.
