Sweep Pattern
  • Thread starter Thread starter wilmath
  • Start date Start date
W
wilmath
Guest
I have created a sweep and I want to create another copy
using the pattern command. I want the copy to be out in
front of the original and also be smaller.
I was able to get it to pattern in the first direction
using direction but when I tried using the second
direction with dimension it was a lot more unpredictable.
I used the radius dimension of the section but it
produced 3 copies at weird orientations
When I am using pattern on a sweep should I use the
trajectory or the section - or both? I tried using the
trajectory but didn't see any dimension to click on.
Rick
14_164641_Sweeppattern.png">
14_164749_proedirectionsweep.png">
