Sweep: one loop per subsection is allowed
  • Thread starter Thread starter dmuir
  • Start date Start date
D
dmuir
Guest
I am trying to create a simple Sweep using Pro-E Wildfire 5.0. This used to work with an older version see tutorial (top part): [url]http://www3.mbs.sd23.bc.ca/staff/dmuir/drafting/assign_c/pro _e/carnegie_mellon_university/tutorial_6/tutorial_6.htm [/url]
After creating the initial sketch if I select the check mark to complete it, the error message "Only one loop per subsection is allowed" appears. On searching this and other sites the recommended solution is to go to the Sketch pull-down and select Feature Tools then Toggle Section, but "Feature Tools" is grayed out and not accessible.
Any suggestions would be appreciated.
Thanks for the file but unfortunately we use a school version and yours is created on a commercial version and ours will not open it.
We found a work around by moving the sketch off the centerline and then it would work. Any ideas why this works and the other doesn't anymore.
Thanks again,
DMuir
