Sweep boss/base issue
  • Thread starter Thread starter Jeff Rivard
  • Start date Start date
J
Jeff Rivard
Guest
Hi all,
ive run into a problem in solidworks.. im trying to create a half circle using sweep boss/base but i cannot get the ending end of the sweep to finish straight
it always finishes on an angle ive posted a picture of the issue.. if anyone knows how to solve this...
thanks.View attachment 979
Sweep vs. Loft
Jeff,
Make a separate sketch for each end. Then make two sketches for your arc'd guide curve.
Use LOFT instead of SWEEP.
LOFT the two end sketches together using both arc sketches as guides.
View attachment 980 View attachment 981
thanks for the reply i will try this and see how it works...
