surface sweep with tangency?
  • Thread starter Thread starter SW
  • Start date Start date
S
SW
Guest
I am trying to create a surface similar to the red surface shown in the image in order to join the two surfaces in cyan and green. The red surface was created using a variable section sweep and is nearly right but the feature does not maintain tangency throughout the sweep.
What is feature to do this?
Thank you,
Sam
You might try using a boundry blend. Create tangent curves at ends and then do a 4 sided boundry blend using the edge of the surfaces and the sketched curves. Specify the boundries to be tangent.
You will not get a g2 surface with a var sec sweep.
Build a network of curves and use a boundary blend.
Mike
