DoubleStud
- Jul 6, 2022
- 501
I have a mountain home where I will have a very tall stone veneer (6" thick including mortar) around the fireplace. How do you folks typically support for these scenarios? Do you put beams directly below the veneer or below the wall it is adhered to? How about if you have stone veneer below as well. Do you just add crush blocks in between floor? Support the veneer all the way to foundation? I am always not sure what is the best way to do this. As you can see, some of the veneer is only on main floor, so for sure I will need a beam.
