  • Congratulations 3DDave on being selected by the Eng-Tips community for having the most helpful posts in the forums last week. Way to Go!
Sulfuric Acid Storage
nicolai
42
Hi Folks
possible to direct me to the applicable codes and guidelines regarding bulk outdoor storage of Sulfuric Acid (98%)
many thanks
1. Are you in the USA?
2. Do you have a code or standard you have to meet?
3. Type of container, average quantity per container
Thks cdafd
application is bulk storage 50m³
what code in the NFPA suite is most applicable ?
many thanks
Explain why your question was posted in the "NFPA fire Code Issues" forum ?
Will you be using Sulfuric Acid in fire protection in some way ???
MJCronin
Sr. Process Engineer
Thks MJcronin
I want to establish the good practice and regulations regarding the storage of bulk sulfuric acid from an fire prevention & protection perspective
Thanks LCREP
is did reviewed FM 7-111F
they dont mention any special fire measure like sprinklers for bulk storage tanks ( i.e 50 m³)
perhaps not a prerequisite for sulfuric acid
my concern is overpressure and subsequent release in case of fire
I think section 2.4.5.2 regarding vacuum breakers, hydrogen gas detection and high level alarms are definitely things to consider. Again they are trying to limit a loss $$ by early intervention.
I take this is not in the USA?
Suggest get a Fire Protection Engineer that deals with Hazardous Materials
There is to many questions, to get a good answer here
