Hello Folks,
For the SMF seismic design requirements, the strong column weak beam approach is required at the connection zone per AISC 341 and 358 which makes me under impression that it is not required for the full length of column to be stronger but only the portion at the connection zone, am i getting it right ? and if so, what extent above and below the connection shall be under this requirement. I have navigated in FEMA but couldn't find any clear requirement.
