nthmrb1
- May 4, 2011
- 2
I am trying to figure out how to calculate if a concrete slab will be safe if I perform a horizontal directional drill beneath it. What calculations can I do to prove that it is safe? I was thinking of proving that the slab is strong enough to span over the 12" bore hole I will do 10' below the slab by using a one way slab calculation but not sure if I am thinking about this correctly.
