Stress intensity factor of bonded plates
Wazy01
49
G'day All
I hope some of you in this forum has the knowledge of the work of Wang&Rose. My question is regarding the article 'A crack bridging model for bonded plates subjected to
tension and bending'by Wang&Rose 1998.
Wand&Rose presented two methods for estimating the stress intensity factor of asymmetric bonded repair : (1) Kirchhoff-Poisson plate bending theory (geometric linear), and (2) Reissner|s plate theory (geometric non-linear).
Following the procedure (Eq. 36) for the simpler case in (1)/geometric linear, and the numerical examples, I am not getting the same presented results (I missing something, and hope your comments help me to figure out). Also, following the presented procedure and examples (Please see attached, summarized example with the procedures)
in my results,
Both the membrane stress intensity factor & the bending stress intensity factor are functions of both (bending and membrane stress) opposite to the presented results in the abovementioned article: membrane & bending stress intensity factors are functions of the membrane stress only and bending stress only, respectively.
Apart from the magnitude values, the membrane stress intensity factor was always > the bending stress intensity factor whereas the presented results in Table(1) & Figure 6 were the opposites.
Have you ever solved or run into a paper where the presented examples in the above paper were solved/with some details!
Do you have any suggestions or comment on the procedure I followed introduced in the attached, please?
Please accept my apologies if you find the question does not fit or should not be here
 https://files.engineering.com/getfile.aspx?folder=9c2224ae-a4ae-457a-afbb-a46a12b55f4e&file=Doc33.docx
