oengineer
- Apr 25, 2011
- 732
I am working on the design of a CMU Lintel using strength design. I am using example 11.4-1 in the Masonry Design Guide. In the example, they checked the lintel for gravity DL + LL, but they do not mention anything regarding lateral Wind Load design for the lintel.
I thought if I just rotate the lintel/beam around on its weak axis and follow the same procedure as shown in the example I should be okay. I am having issues with the Mn > 1.3Mcr check & the required reinforcing. My required reinforcing is not a lot, but when I enter the amount of reinforcing required for the lintel, then my Mn > 1.3Mcr check is not satisfied.
Are there any good examples for lateral load lintel design available? Comments/suggestions are appreciated.
