STEP Translation
  • Thread starter Thread starter dida128
  • Start date Start date
D
dida128
Guest
Hi magenta!
I can tell you what I know, and that is that STEP file is more accurate then IGES (imports from STEP are much better and in most times you don't need to redefine import feature to get solid) and the most advantage is when you export assembly through STEP you wil get in import complete assembly (each component is one part) all in one step file when IGES creates each component export.
dida128@hotmail.com
I am bit confusing.......
In proe step translator comes as standard.
and no need to buy it separatly right??????
