mbstruct
- Jun 28, 2018
- 5
In typical steel beam pockets into concrete or masonry walls, the void is generally grouted solid. AISC commentary mentions that web crippling equations are generally conservative because the tests used to derive the formulas were conducted on bare steel beams without the expected beneficial contributions of any connection or floor attachments. I would imagine the grout filled pocket would provide quite a bit of restraint to prevent the web crippling failure. With that said, for steel beam pockets that are grouted solid, what do you generally consider to be the controlling steel failure mechanism?
