mijowe
- Feb 3, 2003
- 204
I have a load bearing 8" CMU stair shaft and the wall has a 2-hour rating. For steel beams sitting on the wall I typically just use a standard beam with bearing plate. I have been asked to keep my steel, bearing plate included, 4" from the inside face of the wall. 4" being the minimum masonry thickness for a 2-hour rating. IBC Section 714 does a decent job of setting restrictions, but only in the context of MEP / Electrical. Is there specific IBC guidance on sitting non-combustible structural steel on a wall and not altering the rating?
