I have a contractor pushing hard to use Stayform (galvanized stay in place forms) for the base slab of a water bearing structure. The manufacturer themselves have a page dedicated to the use of Stayform as a bulkhead for mat slabs: https://amicoglobal.com/stayform-concrete-forming/projects/bulkheads/
I've already dug deep into this Stayform stuff to assess the shear friction coefficient vs the intentionally roughened surface we specified.
My question is how does the "mesh" not get corroded (first the galv coating and then the steel) and start wrecking havoc in the joint? Sure I can give direction that the Stayform needs to be held back from the formed/unformed surfaces by a cover equivalent to the reinforcement. But we waterstop these joints for a reason, and it's that water is almost surely getting into the joint.
Has anyone dug into this before? If their marketing is to be believed, this stuff has been used in USACE water bearing base slabs as far back as 1999.
