B
bimbo666
Guest
Hi Dear Team,<?:namespace prefix = o ns = "urn:schemas-microsoft-com
ffice
ffice" />
I'm facing upa machining challenge, it's about a machining a blade section of a stator prototype on aluminum, but I really know that the expert aerospace manufacturing engineers do that on a 5-axisCNC milling, right now the companythat I'm working on is new one on all this kind of metalworking, so we're evaluating all the parameters that the process has, to do a future5-axis CNC millinginvestment.
The way Idid all the manufacturing of this prototype was onamilling machinewith a 4-axisrotary indexer, but I did itin 4 zones, each one around 90 degrees, I mean machining all the surfaces that the blade has on a virtual circular quadrant, then I indexed my attachment another 90 degrees and continues the cutting until would be finished.
I wanna know about all the expertise that the manufacturing guys over this forum have, if was a good or bad manufacturing strategie, and if it's bad, which strategie can I use to manufacturing another prototype, using the CNC and the atachmenet I have right now.
Also I wanna know if somebody have experience on the fixture that is used to machine this kind of blades, so if somebody can explain me the rightprogramming strategie
I really appreciate the kindness of any help given
Attached you'll find the stp file, from the model that was machined.
2009-04-16_164103_Ala4p2.zip
Best Regards
Pablo Ulloa
Best Regards
Pablo Ulloa
