hemiv
- Dec 7, 2018
- 94
Hi y'all.
I'm getting tripped up on a PE exam study problem that hopefully you can provide some help with. It's from the Goswami All-in-One guide, 3rd ed., problem 102-001.
In a nutshell, it's this problem: Link
The differences are:
y between A & B = 4'
x between A & B = 4'
y between B & C = 2'
x between B & C = 8'
y between C & D = 5'
x between C & D = 3'
D is 1' below A
3kN load is 20kip in my problem
8kN load is 30k
So in the Goswami problem, all lengths including sag are known.
Is there any reason I can't sum moment about A, get an equation in the form of:
aDx + bDy = c
where a, b and c are known values. Then substitute Dx and Dy with Dcosθ and Dsinθ, so long as θ is known? Then I would have an equation in the form of
aDcosθ + bDsinθ = c
Then solve for the resultant reaction at D, which for cables is also simply the tension load in the cable. For this problem, I'm getting 32.9k. The only problem is, Goswami does it with a different method and comes up with 51.9. I realize that my method is a bit of a long way around, instead of just starting with cutting around joints B and C. But you know, this is for the PE exam and I'd rather be able to just rely on my gut even if it takes 30 seconds longer to solve.
In fact, there are three different ways I'm trying to and coming up with different tension in cable CD every time. Is there some rule I'm missing on this one? I can solve the cables with supports on the same level easily, but for some reason this difference in height between support A and D is throwing me for a loop.
D is 1' below A
8kN load is 30k
aDx + bDy = c
aDcosθ + bDsinθ = c
