Standards
Roxel
Aerospace
Feb 14, 2006
9
Can anyone tell me if Pro/ENGINEER Wildfire 3.0 can be configured to be compliant with BS 8888 (drawings)and is it is simple as selecting BS 8888 from a list as opposed to the ASME American equivalents? Or does it involve changing all the idividual settings for dimension style, default line spacing and text height/thickness etc for noting and so on in accordance with the new standard (hence a knowledge of BS 8888)? Currently looking to upgrade to Wildfire 3.0 from 2000i which is currently set to give BS 308.
Cheers
I am not sure I completely understand your question, but all you should have to do is bring over your .dtl file you already have set up in 2000i. Wildfire 3.0 does not have any standards baked in, but if you have it in a previous version you can always just bring them over to your new installation. Same for your config.pro file.
