Helepolis
- Dec 13, 2015
- 209
Hi all,
Trying to model a spring with both ends closed-&-ground, using the Helix tool and defined by 'Pitch and Revolution'.
I just can't figure this tool out, how the F the parameters in the table work/linked.
various AI chats didn't help, neither google/youtube, nor the laughable "help" of Solidworks, where only the meaning of the different parameters is explained (thanks for nothing!) and not how the feature actually works.
I've never been so frustrated with a Solidworks feature, at a point of just breaking something just the relive the anger.
Just in case here are the parameters of the spring:
SD
- Wire Dia. 1.37mm
- Spring OD 9.83mm
- Total length (end to end) 19.5mm
- Total coils 10
- Active coils 8
- End Type closed-&-ground
SD
