rsbmusicguy
- Mar 21, 2019
- 44
Hey guys,
I recently have been given the task to splice a new glue laminatrd beam to an existing glue laminated beam of the same section and properties for a building in order to accomodate a renovation.
Luckily, the location of the splice is an area where the moment is relatively small with respect to the remainder of the beam. However, in the past I have installed splice plate at inflection points and moment was never a major concern. I am trying to find resources online that provides a beam splice plate and bolt group problem considering both shear and moment.
So far I can see how as the beam deflects, this deflection will put the splice plate into tension and pull on the bolt group but I am having trouble calculating this axial/tensile force. Note I will locate my bolts at the neutral axis of the beam.
Any help is always appreciated!
RSB
RSB
