G
geertdaenen
Guest
Dear all,
I want to create a "spare part" parameter (SP) for each model in an assembly, which can be used in a BOM-list on the drawing of this assembly.
Thescreenshot below will explain a bit more what I want to do:
As you can see, I want to have the parameter "SP" for each part standard be unchecked, but for certain parts the "SP" parameters have to be checked. But as you can see, some parts (e.g. MNP-001321 and 2011134-1032) are checked in certain sub-assemblys and unchecked in other sub-assy's. So this parameter "SP" has to be a parameter which is "assembly dependent".
Offcoarse, the parameter doesn't really need to be checked and unchecked, it also can be a "YES/NO" parameter.
I also have tried to put the models which have to be a sparepart, on a layer. But I cannot get this "layer" into a BOM-list.
Is there anybody who can help me???
