Someone knows how to execute a trail file step by step?
  • Thread starter Thread starter Roberto
  • Start date Start date
R
Roberto
Guest
I
Hello
Try these options :
1. Trail delay : sets the delay in second between trail file steps
2. set_trail_single_step : Yes : enables a trail file to be single-stepped by entering (CR)
I use them often for my job
Try them and see which of these can solve your problem
xcad
to be more spesific..
for the second option, when you press enter you can just roll your trail file, if you want to make changes to your part, assembly or drawing from your trail file you can do it by pressing e. With this way your trail stops running and therefore you can make changes or create a different model.
It is a flexible way for large assemblies, when for some reason, fails to regenerate (when you forget to make a backup), then play the trail file by pressing enter and press e to exit, just one step before the change that cause the regeneration to fail.
Practice with trail file, it is a very efficient option in Proe
regards
xcad
