Solidworks Tutorials by SolidProfessor
  • Thread starter Thread starter achen
  • Start date Start date
A
achen
Guest
SolidProfessor just released a set of SolidWorks tutorials for people switching out of AutoCAD which I found really helpful. Here are the links:
Introducing the transition between 2D to 3D
http://solidprofessorstore.com/public_samples/01_01.wmv
Introduces SolidWorks behavior and Design Intent
http://solidprofessorstore.com/public_samples/01_02.wmv
Explains how to import a .dwg or .dxf file
http://solidprofessorstore.com/public_samples/01_03.wmv
Gives an overview of the DWGeditor
http://solidprofessorstore.com/public_samples/01_04.wmv
Explains how to import a .dwg file into a SolidWorks drawing
http://solidprofessorstore.com/public_samples/01_05.wmv
Explains how to import to a SolidWorks drawing as an embedded dwg format
http://solidprofessorstore.com/public_samples/01_06.wmv
Explains how to import a dwg file into a 3D model
http://solidprofessorstore.com/public_samples/01_07.wmv
Explains how to align and orient imported sketches
http://solidprofessorstore.com/public_samples/01_08.wmv
Their website is: SolidProfessor - Training for SolidWorks and SolidWorks-related Products
Here are some more videos from Solidprofessor:
Introduces the how parts are created using combinations of features
http://solidprofessorstore.com/public_samples/083dsk01_01.wmv
Describes the various components of the SolidWorks interface
http://solidprofessorstore.com/public_samples/083dsk01_02.wmv
Explains how to use Edit Sketch and Edit Part modes
http://solidprofessorstore.com/public_samples/083dsk01_03.wmv
Explains how to use the line tool within a sketch
http://solidprofessorstore.com/public_samples/083dsk01_04.wmv
Explains how to use the rectangle tool within a sketch
http://solidprofessorstore.com/public_samples/083dsk01_05.wmv
Explains how to use the various circle and arc sketch entities
http://solidprofessorstore.com/public_samples/083dsk01_06.wmv
Explains how manual geometric relations can be added to control a sketch
http://solidprofessorstore.com/public_samples/083dsk01_07.wmv
Explains how dimensions are used to define and control a sketch
http://solidprofessorstore.com/public_samples/083dsk01_08.wmv
Explains how to extrude a 2-D sketch into a 3-D part
http://solidprofessorstore.com/public_samples/083dsk01_09.wmv
Explains how to remove material based on a sketch
http://solidprofessorstore.com/public_samples/083dsk01_10.wmv
Thanks for posting the links.
Cheers!
The link that ACHEN provided doesn't work. Try this one instead...
MoreTraining Vidoes for learning SolidWorks
If you are new to SolidModeling all together then what you need is a set of training videos that will guide you through the fundamentals of Solidmodeling. Inspirtech has produced a series of videos that are full of real life examples and excercies. Starting at $39.00
For more information see the samples at Inspirtech.com
SolidWorks Training & Tutorials on DVD - Inspirtech - Free samples
Enjoy,
Al Whatmough
Solidprofessor just released the SolidWorks Certification Preparation course (CSWP/CSWA). The SolidWorks Certification Prep course is designed to help users prepare and successfully pass the CSWP/CSWA exams. The course provides sample problems that covers all major areas of the exam as well as a practice test.
Check it out at SolidProfessor - Training for SolidWorks and SolidWorks-related Products
